    Trying to paste a copied object often results in a prior copied selection being pasted instead
    3 Posts 2 Posters 4.6k Views 1 Watching
      This is a recurring frequent issue -I try to copy and then paste an object and instead it wants to paste whatever was copied to the clipboard prior. Resetting does not fix it - only closing and reopening the file fixes it temporarily.
      Here is an example where I'm trying to cut the solid white "F" hidden behind a gray stroke overtop. I then want to paste it overtop the gray stroke. Doing so results in a paste of the "C" that I copied earlier on in the design process
        @Boldline If I remember correctly, this issue occurred before when copy / pasting a shape.
        If there is an example file (and the steps) I could use to replicate this, please send it by email.
          @Boldline This problem should be fixed in 1.1.048
