    update 1.0.017 RC1
    2 Posts 2 Posters 1.7k Views
      VectorStyler 1.0.017 RC1 release notes
      • Improved: better cursors to indicate rotation, resizing and skewing.
      • Improved: show object center while rotating or skewing.
      • Improved: transparency panel to adjust opacity and mask of the style selected in the appearance panel.
      • Improved: add opacity slider to the color panel.
      • Fixed: Wacom tablet input blocked with some tablet drivers.
      • Fixed: positioning of the document when printing with some printer drivers.
      • Fixed: adjustment filter by object did not use shape or content as a mask correctly.
      • Fixed: shape effect option button was missing in modal shape effect editor view.
      • Fixed: pixelate effect did not render correctly.
      • Fixed: resizing selected nodes only when first node is selected did not adjust control point correctly.
      • Fixed: editing width profile in offset path shape effect.
      • Fixed: when drawing new shapes, use all shape options set in the modal view.
      • Fixed: modifier for regular and normalize option of stars.
      • Fixed: also clear corners of shapes when reseting shape options.
      • Fixed: select all while in shape drawing mode should select all objects.
      • Fixed: deleting the first node in a closed shape did not create a correct approximation of the curve.
      • Fixed: changing a segment to line should set cusp nodes at both ends.
      • Fixed: adjust number of sides in super shape edits with arrow keys.
      • Fixed: pressing tab key in document view should not move focus away.
      • Fixed: show and use transformed shape effect indicators if object has been transformed after the shape effect.
      • Fixed: also move locked layers and objects when moving artboard from context panel.
      • Fixed: constrain point movement with Shift in 4 point distortion.
      • Fixed: copy and paste part of a path selected in the node editor.
      • Fixed: contour is too slow on complex shapes.
      • Fixed: large contour was broken on some shapes.
      • Fixed: crash in character tool.
      • Fixed: freeze in layers panel while working with symbols.
      • Fixed: color filters did not adjust parameters of stacked image effects.
      • Fixed: wrong limits for baseline offset and skew fields in the character panel.
      • Fixed: Hidden command from Object menu was not working.
      • syllieS Offline
        syllie
        I saw a huge improvement in the quality of the pointers on Win10 - that looks so much better now!
        Windows 10 Pro | 22H2
