    Snap to Guidlines Issue
    8 Posts 3 Posters 7.6k Views 3 Watching
    • IgullI Offline
      Igull
      I have attached a video for your delectation 🙂
      Guidline Snapping Issue
      • Objects rarely snap to the guidelines
      • Sometimes it works well giving a feeling of snapping, most times, it just doesn't work at all.
      • The issue seems to be worse in the Y direction.
      • Regular objects like a rectangle or circle work better than created objects.
      • Snapping a node from a created object never works - only the bounding box will snap.
      Neil
        VectorStyler @Igull
        @Igull I cannot replicate this.
        Could you upload the vstyler file that was used in the video, or send it to csraba at vectorstyler.com
          encart
          Works perfect here. https://recordit.co/ccvn1z3cYs
          VectorStylerV IgullI 2 Replies Last reply Reply Quote 0
            VectorStyler @encart
            @encart @Igull I suspect some settings issue with the guidelines. A file might help replicating.
            • IgullI Offline
              Igull @VectorStyler
              Just sent it.
              Neil
              • IgullI Offline
                Igull @encart
                @encart
                Yes, perhaps some conflicting setting I have, I've tried a few that may be obvious, but no luck.
                With show snapping indicators switched on, you can see that occasionally it will snap as the bounding box passes the guideline.
                Neil
                  VectorStyler @Igull
                  @Igull The "Detect Hovering Node" option in preferences should be disabled.
                  This causes snapping to break. I will fix this ASAP.
                  • IgullI Offline
                    Igull @VectorStyler
                    @VectorStyler said in Snap to Guidlines Issue:
                    Great, glad you found something !
                    Neil
