    Some Distortion tools not working
    22 Posts 5 Posters 34.3k Views 4 Watching
    • DazmondoD Offline
      Dazmondo @VectorStyler
      @VectorStyler said in Some Distortion tools not working:
      @Dazmondo Just checked and it works here. Could be something specific to that file (maybe a filter or object option).
      Can you upload or send me the example by email? Thanks!
      I'm creating new documents and using the shape tools and having the same problems
        VectorStyler @Dazmondo
        @Dazmondo send me a file, it might help replicating it.
        • DazmondoD Offline
          Just discovered that editing via the sliders is working see vid:
          https://drive.google.com/file/d/1IGDlQQJ1pz1d-IFhZhA2KinnlcMYsLnr/view?usp=sharing
          • DazmondoD Offline
            Dazmondo
            0_1659010343612_TestQ.vstyler
            Heres the example from the vid
            Thank's
            • Devil DinosaurD Offline
              Devil Dinosaur
              works here, I can change the settings of the inflate πŸ€”
              Fred.
                Boldline @Dazmondo
                @Dazmondo
                Seems to be working here
                0_1659011596357_f914cc38-ad8b-447b-87ff-fd94828c7386-BLD 2022-07-28 at 08.32.55.png
                  @Dazmondo said in Some Distortion tools not working:
                  It is working here also. But one observation, that might be an issue: selecting the effect tool from the toolbox will add a new effect if it does not match the already added effect.
                  Also: select the object and in the Shape Effects panel click the second icon at the bottom. This activates the shape effect editor for the selected effect.
                  • DazmondoD Offline
                    @VectorStyler Damn ---- heres another vid: https://drive.google.com/file/d/1N4Flbov1s7s88hdBz9No776AhrH1ewzW/view?usp=sharing
                    VectorStylerV b77B 2 Replies Last reply Reply Quote 0
                      There seems to be some issue with showing and updating the handles in those editors. I added this to the backlog.
                      EDIT: try a Command+R for refresh / update if the handles are off.
                      b77B DazmondoD 2 Replies Last reply Reply Quote 0
                        b77 @VectorStyler
                        @VectorStyler Could be some glitch related to some setting in @Dazmondo 's Preferences.
                          VectorStyler @b77
                          @b77 said in Some Distortion tools not working:
                          Yes, it could be. But I would need the settings file to see that.
                            b77 @Dazmondo
                            @Dazmondo Switch to Finder > click the 'Go' menu > Go to Folder…
                            Paste this:
                            ~/Library/Application Support/NumericPath/VectorStyler1.0/vector/data/resources
                            Hit Enter.
                            Send the two files (settings.xml and workspace.xml) to the developer.
                            • DazmondoD Offline
                              I've found the problem: For some unknown reason Direct preview of changes was unticked --- now ticked and working as normal
                              b77B VectorStylerV 3 Replies Last reply Reply Quote 2
                                b77 @Dazmondo
                                @Dazmondo Just found the same here.
                                • DazmondoD Offline
                                  Dazmondo
                                  Thanks guys πŸ‘ πŸ‘ πŸ‘ 😌
                                    Ok, but this could also be a bug. When the mouse is released, the effect should apply.
                                      Yes, now I can replicate and it is a bug.
                                      • DazmondoD Offline
                                        πŸ‘
                                          Boldline @Dazmondo
                                          The next bug fix build release is hereby dedicated to @Dazmondo for the numerous recent Bug discoveries both intentional and the inadvertent!
                                          Special thanks to @VectorStyler for hitting clean-up πŸ˜ƒ
