Dropdown Values UI/UX
I think that you're using the Dropdown list and Dropdown Slider Icons in reverse, when I click the Arrow Up/Down Icon I expect a DROPDOWN LIST which I can slide UP and Down(exactly as the arrows indicate), not a SLIDER. The same applies to the Arrow Down Icon, I expect a Slider bellow the Icon.
Hope it Helps to the UI/UX experience
Agree with this, will think of better the icons for this case.
@vectoradmin Great! Thank you very much
btw I have a Question, in performance Settings I dont see the METAL option, only Software/System GPU/OpenGL is this normal? I have a MacBook Pro 2018 15" -
"System GPU" is "Metal" on Macs.
Renamed it because the windows port is being worked on.
But I will be change it back to Metal. -
@vectoradmin Oh, okeey thanks, also is there a way to get the canvas drawn before I begin dragging? It would increase the User Experience and Satisfaction working by quite a lot in my opinion
The issue demonstrated here:
Yes, I think this can be fixed.
@vectoradmin @vectoradmin Can confirm that the panning issue is fixed! The naming to Metal is changed too! The one remaining is confusing icons, but that's for the long-term, so take your time!
Thank you!
The panning issue is still present in Outline Preview mode though. Anyway thankyou very much
