    Artboard margins ?
    22 Posts 2 Posters 26.5k Views 2 Watching
      VectorStyler @B-Vs-V
      @PatrickM said in Artboard margins, what did I do ?:
      I can only add margins to one of my two artboards
      This one sets the margins of the current artboard. Use the pageup/pagedown to go to an other artboard and set the margins for that.
      Another way is to select multiple artboards using the Artboard Tool, and then use the artboard options.
      • B Offline
        B-Vs-V @VectorStyler
        @VectorStyler This what I do/did and there is an issue (I think) with margins' preset:
        1. I go to: File-->New document setup
        By the way, I'm wondering what is "Shape units" and why this value of 90,31mm ?
        1. I setup the document : 2 artboards & size of the artboards (PP 4/3)
        So far so good
        1. I then setup the margins : by going to Artboards-->Format--> Margins
          and I create a preset with the ad hoc margins values... but when I create a new doc and want to adjust the margins' values with the preset, I still get 0. Or I do somethiong wrong or the values are not stored.
          @PatrickM Can be replicated! will be fixed ASAP.
          • B Offline
            @VectorStyler glad I can help ☺ Great for the fix 👍
            • B Offline
              @VectorStyler Fixed, very nice.
              I've found how to delete a preset (Preset Manager) but I can't found how to see margins values in mm when I setup a new document.
              When I setup a new document, I see margins values in pt. When I check in "Artboard options", I see them in mm (as I defined them).
              Not a big deal but I prefer to see these values in mm when I design a document in VS .
              Thanks.
                @PatrickM It will show in MM only after the document options are confirmed (which is a bit of a problem, since they are being edited).
                • B Offline
                  @VectorStyler I wanted to test some patterns in VS: I go to 'New Doc Setup' as usual, then determine the size of the artboards and I get the margins of my previous document.
                  This time, margins are not necessary. Would it be possible to get '0' for a new document or maybe better, a reset button ?
                  Thanks,
                  P.
                    @PatrickM said in Artboard margins ?:
                    A reset button is I think the best solution here.
                    But, there is a solution already. Create a preset with the preferred default settings and then just select that from the Style drop down.
                    • B Offline
                      @VectorStyler yes, indeed. It is even nicer to go by presets in VS.
                      We would have to store a preset with '0' then.
                      Edit : Done and it is fine. I always try to avoid using the keyboard when I can.
                      • B Offline
                        @VectorStyler A simple idea is that it depends on the unit used when creating a new document: if it is in px, the data of the guides etc. are given in px, and so on. I don't know the feasibility of this.
                          @PatrickM I added this to the backlog, I think it is easy to fix it.
