    update 1.1.067
    25 Posts 7 Posters 6.1k Views 6 Watching
    • J Offline
      Jayanta Das @VectorStyler
      @VectorStyler After resetting its working now. Will test others.
      Mac Mini M4 Pro | 24Gb
      WIndows 11 | Intel i5 11Gen
      Wacom Intuos Pro
      • J Offline
        • Changing gradient color mode in gradient panel may result in wrong resizing.
        Still panel resizes and hide some option like flip gradient color position
        recording
        Wacom Intuos Pro
          VectorStyler @Jayanta Das
          @Jayanta-Das said in update 1.1.067:
          Will fix this!
          • J Offline
            Jayanta Das
            Some Pen tool issues, I will post it in detail.
            Wacom Intuos Pro
            • H Online
              Harry
              After updating via VectorStyler's Help\Check For Updates, Revo Uninstaller shows previous build also. It could be messy after several updates.
              Is it meant or should we update manually?
                encart
                @VectorStyler I remember after the release of Affinity V2 you mentioned that you didn't want users to be disappointed when 1.2 came along . Looking at the number of small improvements you've made in the meantime, I think, at least here on the forum, we can turn a blind eye to many things:) However, I don't think this will be necessary.
                BoldlineB VectorStylerV 2 Replies Last reply Reply Quote 3
                  Boldline @encart
                  @encart I had mentioned something similar to @VectorStyler the other day. Even if 1.2 is released not "complete" (according to @VectorStyler standards) and then adds things in and updates it as he goes along afterward, no one is going to complain or think less of him or compare it to the "other" recent big release. The pace of bux-fixing build releases has slowed some over the last few months compared to the typical torrid pace, but that's the only sign we can see that 1.2 is the focus on the background. As @encart mentioned, the quality of bug fix builds despite working on 1.2 at the same time has been amazing. Seeing the issues still get fixed consistently and even a few new add-ons to boot has made it easier to wait on 1.2's eventual release.
                    VectorStyler @Harry
                    @Harry said in update 1.1.067:
                    It should remove the previous version on Windows. If not, this is a bug in the installer.
                    Does it show up twice in the add/remove programs?
                      VectorStyler @encart
                      @encart said in update 1.1.067:
                      There is good progress made on that target also, but it is not going to be ready this (calendar) year.
                        Subpath @VectorStyler
                        There is no need to rush from my side, and not everything has to be super perfect.
                        My appreciation for VectorStyler will not diminished in the least.
                          b77 @VectorStyler
                          @VectorStyler said in update 1.1.067:
                          • Clicking with the artboard tool on a group to create an artboard of that size.
                          Is this working? I tried both with a group and with a selection of objects and
                          clicking (or double-clicking) the Artboard tool doesn't create an artboard
                          around the selection, and neither clicking or double-clicking the objects
                          does anything.
                            encart @b77
                            @b77 I wondered too. Group the objects and move them outside the artboard area. If you click , when they are not selected then a new artboard will be created. https://recordit.co/LimXtzH3Na
                              encart
                              Merge nodes at center, button in Path panel and Context panel.
                              I wanted to test this feature and accidentally discovered that hover over these icons has the same result as clicking: 0_1669672443475_screenshot_20221128_225311.png
                                b77 @encart
                                @encart Thanks for the video — indeed it works if I deselect the group first. But I'm not sure why is that needed?
                                  b77 @encart
                                  I wanted to test this feature and accidentaly discovered that hover over these icons has the same result as clicking.
                                  Replicated here. You need to disable 'Preview Shape Combine' in Prefs > Document Editor for now to avoid this.
                                    @b77 said in update 1.1.067:
                                    On a side note, I noticed today that if this is selected, anything you scroll over will be added to the history panel as if it were an applied step. @VectorStyler is there a way to not "count" these in the history until clicked on?
                                      VectorStyler @b77
                                      This is a bug.
                                        Yes, this happens if path operation preview is enabled.
                                          @Boldline said in update 1.1.067:
                                          I think this should not be added to history, this looks like a bug.
                                          • J Offline
                                            Jayanta Das
                                            @VectorStyler sent you a mail about some Pen tool issue I found in VS.
                                            Wacom Intuos Pro
