    update 1.1.067
    25 Posts 7 Posters 6.1k Views 6 Watching
      VectorStyler @encart
      @encart said in update 1.1.067:
      Looking at the number of small improvements you've made in the meantime, I think, at least here on the forum, we can turn a blind eye to many things:)
      There is good progress made on that target also, but it is not going to be ready this (calendar) year.
        Subpath @VectorStyler
        There is no need to rush from my side, and not everything has to be super perfect.
        My appreciation for VectorStyler will not diminished in the least.
          b77 @VectorStyler
          @VectorStyler said in update 1.1.067:
          • Clicking with the artboard tool on a group to create an artboard of that size.
          Is this working? I tried both with a group and with a selection of objects and
          clicking (or double-clicking) the Artboard tool doesn't create an artboard
          around the selection, and neither clicking or double-clicking the objects
          does anything.
            encart @b77
            @b77 I wondered too. Group the objects and move them outside the artboard area. If you click , when they are not selected then a new artboard will be created. https://recordit.co/LimXtzH3Na
              encart
              Merge nodes at center, button in Path panel and Context panel.
              I wanted to test this feature and accidentally discovered that hover over these icons has the same result as clicking: 0_1669672443475_screenshot_20221128_225311.png
                b77 @encart
                @encart Thanks for the video — indeed it works if I deselect the group first. But I'm not sure why is that needed?
                  b77 @encart
                  I wanted to test this feature and accidentaly discovered that hover over these icons has the same result as clicking.
                  Replicated here. You need to disable 'Preview Shape Combine' in Prefs > Document Editor for now to avoid this.
                    @b77 said in update 1.1.067:
                    On a side note, I noticed today that if this is selected, anything you scroll over will be added to the history panel as if it were an applied step. @VectorStyler is there a way to not "count" these in the history until clicked on?
                      VectorStyler @b77
                      This is a bug.
                        Yes, this happens if path operation preview is enabled.
                          @Boldline said in update 1.1.067:
                          I think this should not be added to history, this looks like a bug.
                          • J Offline
                            Jayanta Das
                            @VectorStyler sent you a mail about some Pen tool issue I found in VS.
                            Mac Mini M4 Pro | 24Gb
                            WIndows 11 | Intel i5 11Gen
                            Wacom Intuos Pro
                              VectorStyler @Jayanta Das
                              @Jayanta-Das said in update 1.1.067:
                              Got it. The node closing control point move is a bug that can be replicated.
                              The opposing handle of starting node was not shown before either in VS, and I'm not sure if this will be added for now.
                              • H Online
                                Harry @VectorStyler
                                @Harry said in update 1.1.067:
                                Revo Uninstaller shows previous build also
                                It should remove the previous version on Windows. If not, this is a bug in the installer.
                                Does it show up twice in the add/remove programs?
                                I cannot say as I don't use add/remove programs for uninstalling.
                                As I remember, in Windows app list, VS appeared once.
