update 1.0.020 of RC1
VectorStyler 1.0.020 RC1 release notes
- Improved: overprint support for object styles and spot colors.
- Improved: support for MacOS based hyphenation.
- Improved: change font size and scaling factor when resizing text.
- Improved: option for proportional text, image and linked content scaling.
- Improved: hold Option when scaling text frame to scale font also.
- Improved: hold Shift when clicking on a color to change text color inside text frame (instead of the frame fill).
- Improved: grid shape tool to allow odd number of columns.
- Improved: adjust blend position with a separate transfer function.
- Improved: show text content as default object name in then layers panel.
- Fixed: copy and paste text frame did not detach text content.
- Fixed: OpenType based kerning bugs.
- Fixed: do not truncate font name in font list.
- Fixed: ordering in font style menu.
- Fixed: undo fill style change of text frame.
- Fixed: elastic warp should add nodes from then first click.
- Fixed: some spot colors did not import correctly from PDf and AI files.
- Fixed: exporting fonts to PDF and PS files.
- Fixed: text shape highlight outline path is not updated.
- Fixed: various scrubby scrolling issues.
- Fixed: handling the enter key in text shape and frame editing on Windows.
- Fixed: setting the layer color on Windows closed the view after the first click.
- Fixed: delayed menu opening on Windows.
- Fixed: corner editor jumps for some shapes.
- Fixed: default tab spacing should use the fixed space.
- Fixed: deleting a node changed a neighboring corner type.
- Fixed: duplicating artboard did not correctly duplicate blend object.
- Fixed: selection in numeric field did not always work.
- Fixed: use Shift+ to speed up scrubby scrolling.
- Fixed: cannot scale at small zoom.
- Fixed: text frame knob is tool close to corner.
- Fixed: new document should use last created document artboard size.
- Fixed: keep last brush used in the brush tool, if it was a stroke preset also.
- Fixed: use geometric order by default in alignment panel.
- Fixed: show override font of selected text shape.
