    Glyphs panel: glyph categories are not shown for certain fonts
    12 Posts 2 Posters 12.6k Views
    • A Offline
      Arde
      E.g., for Calibti (Windows system font) all glyphs are shown, but no glyphs for any of the sub categories:
      This is on macOS where I installed the font (Calibri Regular; it is OpenType TrueType flavor), but the same error occurs also on Windows 10 (latest build).
      The glypsh when shown and intensively browsed, also stop being drawn sooner or later wo there might be some memory leaks in this panel.
        VectorStyler @Arde
        @Arde In the "Show" field (at the bottom of the panel), select the "All Glyphs" mode. Are the glyphs shown in that case?
        The Calibri I have on mac does have some subscript alternates, so this might still be a bug.
        Are the glyphs shown if the panel is closed and reopened?
        • A Offline
          Arde @VectorStyler
          @vectoradmin said in Glyphs panel: glyph categories are not shown for certain fonts:
          Yes, they are. The panel is empty only if I choose any of the sub categories. It is font specific so if I use e.g. Helvetica Now (OpenType PS flavor), I can see the list of glyphs in all sub categories (as long as there are glyphs in those). Some fonts also seem to list glyphs (that is, e.g. 6 glyph slots appear as if something were listed, but all slots are just empty).
          When I view e.g. Callbri Regular Supercript (sups) using InDesign, I get the following:
          ...but just a black board when viewing the same in VS (both Win and macOS; note though that the Calibri I installed is the Windows font so I am not sure if it is the same that you have -- this is a huge font that has over 6,000 glyphs).
            VectorStyler @Arde
            @Arde it looks like those alternates are not detected by VS. I add this as a bug to the backlog.
            • A Offline
              Arde
              Related to this, even for fonts like Helvetica Now Text, for which glyph categories are shown, only certain categories (those related to OpenType features, but these, too, are shown only partially so e.g. Stylistic Sets are not listed) are shown. But regular Unicode blocks are missing (including character set based categories like Basic Latin and Latin 1, Greek, etc., and common categories like Symbols, Currency, Math Symbols, Numbers, etc.)
              This is how Photoshop shows categories for Helvetica Now Text (just an example, the same applies to any font that has similar categories):
              ...and this is how VectorStyler currents shows them (both macOS and Windows versions):
              Is this by design or do you plan to include also the regular glyph categories and this just has not been implemented yet?
                VectorStyler @Arde
                @Arde This looks like a bug. It could be that some of the OpenType categories are not detected correctly. I plan to fix it.
                  VectorStyler @Arde
                  @Arde This has been improved in the new build (1.0.022). I tested it with multiple OpenType fonts that were not working properly before. Let me know if there are any issues.
                  • A Offline
                    Arde @VectorStyler
                    Thanks. I can see that e.g. glyphs of Calibri get listed But I still cannot see the regular Unicode blocks listed. Perhaps this is by design? Basically listing the OpenType features as categories is more useful.
                      VectorStyler @Arde
                      @Arde The regular unicode blocks were not there originally, but this should be easy to add. Will be in the next build
                      • A Offline
                        Arde @VectorStyler
                        @vectoradmin Thanks, now they are there -- great!
                          VectorStyler @Arde
                          @Arde In the Glyphs panel menu, the Unicode Blocks menu item has some options to reveal other blocks.
                          • A Offline
                            Arde @VectorStyler
                            Wow, the features of this app are just incredible!
