    Merge not working correct
    5 Posts 2 Posters 5.5k Views 2 Watching
      MajorTom
      Hello @VectorStyler,
      if i select the group in attached file, and press merge the result is very strange.
      100% reproducible at my side.
      If I press in that situation undo, the result is not as expected too. One element is not at the correct position.
      0_1674902121137_bug_report.vstyler
        VectorStyler @MajorTom
        @MajorTom yes, can be replicated here also.
        There seems to be a bug in how the transformations are expanded, also breaks the convert to curve operation.
        Will be fixed ASAP.
        Workaround: ungroup first and then merge.
          @MajorTom Were these shapes copied using "Clone"?
          That might be where the bug is.
            MajorTom @VectorStyler
            shape created, then Command+c and Commaned+v then rotated that one and the rest with Option+D.
            Yes, you are right cloned.
              @MajorTom This issue should be fixed in build 1.1.080
