    Creating seamless Pattern for Pattern Fills
    10 Posts 3 Posters 12.8k Views 3 Watching
      Thought it would be interesting for anyone, how to
      create seamless Patterns for Pattern Fills in VS.
      Which is what this Tutorial is about.
      Here is the video showing my steps, re-upload
      Made already a Tutorial how to create a Pattern fill
      with clipped Shapes. Which can be found in Tutorials.
      The video also contains a few explanations
      it is 2:45 min long and contains four parts
      0:00 to 0:45
      the advantage of using grouped shapes
      and clone them for seamless pattern making
      0:45 to 1:30
      why the clones are created in one go and
      how to arrange them
      1:30 to 2:00
      how to get the general shape for the
      pattern filling from the clones
      2:00 to 2:45
      finally creating the pattern filling
      and the result the seamless pattern filling
      Have fun being creative 🙂
      Important Note about using nested groups.
      Creating a seamless pattern with nested groups could cause
      several problems if you clone them like here.
      For cloning and positioning, you could take stylized objects
      and then replace them with the original before cutting.
      Or you could try to use the "Tiling Pattern Content" role. How
      to do this is described in the manual.
      1 Reply Last reply Reply Quote 8
        seamless pattern, a few other tries
          fewerjunk
          Here's what I got, first try. I think I'm missing something.
          0_1683562816804_Objects_Clone_Group_MESS_VS.vstyler
            VectorStyler @fewerjunk
            @fewerjunk Was the pattern expanded in this file?
              Subpath @fewerjunk
              @fewerjunk
              To create pattern fills in the way I have described here
              I think it's better to stylize the shapes, for position the pattern
              you like and replace them then with the original before cutting them.
              But its also possible to create the Pattern without this Step.
              There are two reasons for this
              First,
              I use the "Select Transformed Members of a Group" Tool.
              This Tool selects a single object in a group rather than a
              single or multiple groups.
              But it is possible to use the Freehand Lasso tool
              to select the group you want to move.
              Secondly
              Moving groups within groups, mirror or rotating groups which contain
              groups can cause transformation problems in Vectorstyler.
              Especially when you clone them. For example, the groups don't
              move the way you expect.
              It can also be helpful if you combine shapes with the same color.
              You get groups that are easier to handle.
              Here some Pictures and a Pattern Result
              Cutting Scheme and Stylize Shape
              combined shapes
              Pattern Template for the Preset after cutting
              the pattern
                @fewerjunk
                This pattern was created using the "Pattern Tiling Content" Role
                which is easier to do than the method I show in my tutorial above.
                I used the Hex Grid, the outline could be disabled
                  fewerjunk
                  Here's what I got for my efforts:
                    fewerjunk
                    This doesn't appear to "just work". Working depends on what you do and how you do it which varies depending on what you're trying to do. Procedurally this seems to work a lot easier, but with fewer options and more effort.
                    Programmatically, this isn't working for me. It could be something I'm doing or not doing or not understanding. Or it could be the program. Or some combination of the two.
                    I like what VectorStyler is trying to do. It's the trying to do it that's causing me problems.
                      @fewerjunk Got the crash report. I will try to find the issue and have a fix as soon as possible.
                      Were there some specific steps that lead to this crash.
                        @fewerjunk Managed to replicate the crash. The fix will be in the next build.
