    Shapes edited with transform tool prior to converting to curves have odd results
    6 Posts 2 Posters 6.0k Views 1 Watching
      This seems like a regression. Shapes drawn and adjusted prior to converting to curves produce unwanted issues when pulled with the transform tool
      0_1687106498706_965475e4-21d7-42e2-a84f-605a09a77d5a-CleanShot 2023-06-18 at 12.41.29.png
        @Boldline Is the "Transform Stroke" option enabled?
          @VectorStyler yes, if you're referring to this setting in the document preferences
          0_1687107159119_c1c5a225-dc5b-4777-b4f0-47573bfde124-CleanShot 2023-06-18 at 12.52.14.png
            I restarted VS entirely and now it works. Previously I had closed out all the open files and made a new one and it had persisted. Should have tried that as well before posting. Solved for now. thanks
              The issue eventually returns and requires a restart of VS to correct it. I saved the messed up rectangle and pasted it in a new file alongside a working one in case that might help figure out the issue
              Here is the file: 0_1687145455729_rectangle issue.vstyler
              0_1687145421652_c736248e-2771-4db6-96e1-38abf92cbc72-CleanShot 2023-06-18 at 23.28.35.png
                @Boldline I will try to find out what could cause this.
