    update 1.1.092
    3 Posts 3 Posters 681 Views 2 Watching
      VectorStyler 1.1.092 release notes
      • Fixed bug in shape union and merge.
      • Scaling text could change the font size, also for default font size.
      • Fixed regression in opacity mask boundary for outlines.
      • Fixed glyph visibility issues with certain transformation.
      • Selecting with a box mode in deep select mode should not select both group and member objects.
      • Do not repeat colors in the color palette when pasting or importing.
      • Better display refresh when changing between documents.
      • Aligned stroke with local transform did not render correctly.
      • Allow Shift+click on Layer panel object selection knob.
      • Enable spot plate in printing if visibility is enabled.
      • Fixed refresh issues when editing inside clipped groups.
      • Adjust the size of the updated image if proportions change.
      • Pasting an artboard should keep it selected.
      • Allow multiple color selection in the palette panel.
      • Fixed object style issues when using object roles.
      • Better handling of custom toolbox icons.
      • Allow drag and drop of new color into color palette bar.
      • Show artboard edges over objects.
      • General stability improvements.
      B BoldlineB 2 Replies Last reply Reply Quote 5
      • B Offline
        B-Vs-V @VectorStyler
        @VectorStyler Thanks ☺
        A new feature to help with the layout of documents ☺
          @VectorStyler said in update 1.1.092:
          Thank you - The issue with fixed now on the laptop where I was previously seeing this problem!
