    Cannot use any other color mode other than RGB.
    4 Posts 2 Posters 4.6k Views 2 Watching
    • P Offline
      pentool
      I was playing around in VS causing nothing but trouble. After awhile something happened and the program came to the point where I was no longer able to switch to any other color mode but RGB.
      I was already trying to repro a crash when this happened and decided to stop the video and show it. I am not sure what exactly caused this and why but you can see on the video when I select a shape and switch to HSB color mode, as soon as I click on one of the HSB sliders and try moving it the mode immediately jumps back to RGB mode.
      Forward to 2:00 minutes to see it.
      https://www.youtube.com/watch?v=ssVCUAbxT1E
      Settings and Workspace files:
      https://www.dropbox.com/scl/fi/k0y8apnhhw1kwhmkuo63v/VS-settings-workspace-202308030132.zip?rlkey=aq0ahrhowh9dsbhi1ymttci0t&dl=0
      VS 1.1.095
      • P Offline
        pentool
        It was something with the workspace and/or settings file. Once I removed both, the sliders are working ok. Will try to break it again... won't give up 🙂
          VectorStyler @pentool
          @pentool Added this to the backlog, I will try to replicate it using the workspace and settings files
            @pentool Replicated the bug here also, the fix will be in the next build.
