    Grid Editor: Cannot remove grid color
    6 Posts 3 Posters 6.6k Views 3 Watching
    • P Offline
      pentool
      Once you assign a color to the grid in the Grid Editor you cannot remove it.
      By default the grid color in the grid editor is transparent (aka no color) so you will see the grid color assigned to the grid in the Document Setup dialog.
      When you click on the color swatch in the Grid Editor and switch to the Palettes tab in the popup, there's a "no color" swatch but even if you click that the grid color won't be removed.
      VS 1.1.097
        b77 @pentool
        @pentool There is a 'Clear Grid Color' command in the menu of the Grid panel:
        P 1 Reply Last reply Reply Quote 1
        • P Offline
          pentool @b77
          @b77 Well, that’s very user friendly that in order to clear a swatch color one has to close the dialog, bring up a panel, open it’s menu and select a command. How come I didn’t think of that! LOL
            VectorStyler @pentool
            @pentool Will fix this.
              b77 @VectorStyler
              @VectorStyler I hope the 'Clear Grid Color' command in the Grid panel's
              menu will still be available. It's faster to do it from the panel.
                VectorStyler @b77
                @b77 said in Grid Editor: Cannot remove grid color:
                I hope the 'Clear Grid Color' command in the Grid panel's menu will still be available. It's faster to do it from the panel
                Yes, it will stay there.
                The only bug here is that selecting the No color in the palette drop down should work.
