    build 147
    1 Posts 1 Posters 683 Views
      VectorStyler beta 147 release notes
      • Improved: added distance (gap) snapping mode.
      • Improved: added distance indicators when snapping to objects or object distances.
      • Improved: improved performance when interactively changing objects (moving, scaling, and others).
      • Improved: performance improvements for panning, zooming and rotating views.
      • Improved: additional performance improvements for panning, zooming and rotating views.
      • Improved: performance of rendering stroke outline styles.
      • Improved: copy all decimals when copying text from number fields.
      • Improved: enabled real time preview of slider values in number fields.
      • Improved: added a restart button to preferences change notification.
      • Fixed: stroke width in scaled point text should not be stretched.
      • Fixed: closing path ends should result in a cusp node.
      • Fixed: stroke width on AI imported text.
      • Fixed: dismissing arrow popup in stroke popup should keep the stroke popup open.
      • Fixed: stroke alignment on closed shapes should not depend on the path direction.
      • Fixed: copy and paste text in file save dialog.
      • Fixed: keeping correct object hierarchy when importing some SVG files.
      • Fixed: various crashes in the user interface.
      • Fixed: purge history button in history panel.
      • Fixed: undo and redo for multiple copies resulting from transform repetitions.
      • Fixed: crash when selecting brush styles without an open document.
