    Bounding box in not align to centre
    8 Posts 3 Posters 9.1k Views 3 Watching
    • J Offline
      Jayanta Das
      As we can see in the screenshot the bounding box in not centre align. It is some point above the object.
      Mac Mini M4 Pro | 24Gb
      WIndows 11 | Intel i5 11Gen
      Wacom Intuos Pro
        VectorStyler @Jayanta Das
        @Jayanta-Das Are there some image effects applied on those objects.
        The bounding box is calculated around the object shape, and does not include the extensions resulting from image effects.
        • J Offline
          Jayanta Das @VectorStyler
          @VectorStyler Yes there is image effects applied on this object. But I have seen object without any effects have same issue. Below objects don't have any effects applied
          Wacom Intuos Pro
          • J Offline
            Jayanta Das
            Below you can see it clearly
            Wacom Intuos Pro
              b77 @Jayanta Das
              @Jayanta-Das Attach a test file with that object or send it directly to the developer.
              • J Offline
                Jayanta Das
                Yes sure
                0_1693753943233_Bounding box.vstyler
                Wacom Intuos Pro
                  @Jayanta-Das Cannot replicate on Mac, but it might be an issue on Windows with a display shift of how highlights are drawn.
                  I opened a bug on this one.
                    @Jayanta-Das This can be replicated on windows with 125% screen scaling. I will try to find a fix for it.
