    Removing Gradient Mesh Color Removes Path
    9 Posts 3 Posters 9.9k Views 3 Watching
    • _ Offline
      _NM_
      VS 1.1.104: Please follow the link for a demonstration.
      https://app.screencast.com/5nBoyVX2QEKQI
      Thanks.
      macOS Sonoma 14.5 - MacBook Pro 16" - Apple Silicon M2 Max
        VectorStyler @_NM_
        @_NM_ Yes, this happens when the object is selected. It is removing the object fill, which is a gradient mesh.
        If you want to change the opacity of a single node in the mesh, then select the node and adjust the Opacity slider.
        • _ Offline
          _NM_
          Thank you. The behavior that I pointed out is atypical for drawing programs.
          The mesh was applied to the fill, and not to the stroke. When I apply a mesh, and remove the mesh color, the entire path is removed. When I change the fill back to a solid color and then remove the color, then the path remains.
          Based on other apps in the industry, I expected that:
          1. Applying the mesh to the fill should not remove the path's stroke.
          2. Applying a blank color to the mesh should not remove the entire path.
          If memory serves me correctly, previous versions of VS would first duplicate the path and apply a mesh to the duplicated object rather than replace it. The burden of duplication when applying a mesh gradient is now placed as an extra step on the user.
          b77B VectorStylerV 3 Replies Last reply Reply Quote 0
            b77 @_NM_
            @_NM_ The oldest available version is 1.1.083:
            https://vectorstyler.com/releaselog/#build-11083
            Is that one working as you describe?
            _ 1 Reply Last reply Reply Quote 0
              VectorStyler @_NM_
              @_NM_ said in Removing Gradient Mesh Color Removes Path:
              I will try to replicate and fix these issues.
              • _ Offline
                _NM_ @b77
                @b77 I think it was version 1.0.98, the first version I tried where it behaved differently.
                  VectorStyler @_NM_
                  This happens in Illustrator also, when an object is turned into a mesh, the stroke is removed.
                  It would be an easy change to keep the stroke, but it would cause a host of other issues.
                  1. Applying a blank color to the mesh should not remove the entire path.
                  I replicated this and it will be fixed in the next build.
                  _ VectorStylerV 2 Replies Last reply Reply Quote 0
                  • _ Offline
                    _NM_ @VectorStyler
                    @VectorStyler Thank you again. I have not used an Adobe application since CS6, after which they switched to a subscription model. Therefore, my most recent experience is based on InkScape and CorelDRAW.
                      VectorStyler @VectorStyler
                      @VectorStyler said in Removing Gradient Mesh Color Removes Path:
