    beta update 1.2.002
    21 Posts 5 Posters 39.8k Views 4 Watching
      VectorStyler 1.2.002 release notes
      • General stability improvements.
      • Fixed color popover slider regression.
      • Iconified panels in docked mode.
      • Better dash support on large shapes.
      • Snapping to artboard guidelines.
      • Fixed bug in showing current font from paragraph style of highlighted text.
      • Do not include settings into workspace.
      • Delete recent documents with delete key, in template list.
      • Option to preview eraser and path brush shapes in fitted mode.
      • Fixed regression in the trim and join tool.
      • Selecting corner type should apply to selected node only.
      • Improvements in shape builder and bucket fill tools.
      • Fixed regression in envelope corner tool.
      • Fetch envelope shape when creating envelope distortion.
      J B BoldlineB 3 Replies Last reply Reply Quote 5
      • J Offline
        Jayanta Das @VectorStyler
        @VectorStyler Thanks for the new build.
        Some issues I would like to highlight
        1. I can't change the UI scalling in setting
        2. Docked panel doesn't stay after restart
        (Solve after deleting the NumericPath folder in AppData folder)
        Mac Mini M4 Pro | 24Gb
        WIndows 11 | Intel i5 11Gen
        Wacom Intuos Pro
          VectorStyler @Jayanta Das
          @Jayanta-Das Both seem to be issues caused by the inability to write the settings / workspace files into the user folder.
          • B Offline
            B-Vs-V @VectorStyler
            @VectorStyler said in beta update 1.2.002:
            @VectorStyler Is this the problem I've experienced of not being able to save permanently some settings? Thanks ☺
              VectorStyler @B-Vs-V
              @Pat said in beta update 1.2.002:
              No, this was another issue, when saving and reusing workspaces, it included the settings also (does not now).
              About saving the settings: the user folder should be VectorStyler1.2 now.
              Please check if this folder is created and if the settings.xml file is modified (I tested here and it does).
              If not, then it might be again some write issue problem, see the post above by @Jayanta-Das
              Remove the whole NumericPath folder and retry.
                Anyone else having issues getting the update to download? I've been trying on and off all day and the update crawls and then cancels out. I tested other sites and downloads and had no issues. I guess I'll try again tomorrow
                0_1696721261920_4d6856a2-1961-48e1-b1c7-a8e631663f3f-CleanShot 2023-10-07 at 19.26.05.png
                L VectorStylerV 2 Replies Last reply Reply Quote 0
                • L Online
                  Li Xiao @Boldline
                  @Boldline No problem for me
                    @Boldline said in beta update 1.2.002:
                    Tested the download here and it worked. Could have been some temporary congestion issue.
                    • B Offline
                      @VectorStyler Sorry to come back to this point, but it's not very clear to me: do the two v.1.1 and beta 1.2 install independently this time, and can they both be used on the same computer? Thanks ☺
                        Partially solved. The MSI installer will try to install over the existing one (try renaming the app folder in Program Files).
                        But the user folders are separate now.
                          @Pat I will try to find a solution for the MS Installer issue by tomorrow.
                          • B Offline
                            @VectorStyler Thank you. I'm hesitant to install the beta to test it as long as it overwrites v. 1.1 but there's no hurry as far as I'm concerned ☺
                              This is working so much better now and I love the ability to reduce the panels down to just icons when more screen space is preferred. Very slick! Would it make sense to have tooltips on the icons to allow for quick reference for newer users?
                              • J Offline
                                Jayanta Das @Boldline
                                @Boldline Is it showing just the icons in Mac? In windows there is still icon with the title.
                                Wacom Intuos Pro
                                  Boldline @Jayanta Das
                                  @Jayanta-Das Yes, clicking on the arrow shrinks it to icons only now. no titles are shown at all. Here is a video
                                  The canvas/artboard jolts some each time you shrink or expand the panels, but I assume that could be fixed in time.
                                  • J Offline
                                    @Boldline In Windows it still shows the tile.
                                    Wacom Intuos Pro
                                      @Jayanta-Das Can it be resized to smaller size?
                                      • J Offline
                                        @VectorStyler Can't resize to smaller size. You can see that when I drag to right to shrink it become more broader.
                                        here is the Recording: link
                                        Wacom Intuos Pro
                                        • J Offline
                                          Jayanta Das
                                          @VectorStyler Can you put the limit to minimum size of panel till the icons on the bottom get cropped. To understand what I mean here is the recording Link
                                          Wacom Intuos Pro
                                            @Jayanta-Das said in beta update 1.2.002:
                                            The video link is not working from here.
                                            There seems to be a bug when trying to resize the docked iconified panels.
