Impossible to trace with Pen tool
I can use shapes, the pencil and the brush, but nothing can be traced with the Pen tool... Never happened before.
I can continue a drawing with the Pen tool but no tracing when I start a new one.
@Pat I encountered this issue in both versions 1.1 and 1.2. It occurred on two different computers as well. After restoring defaults, the issue was resolved. I always thought it was a problem with my own settings, but I couldn't find the cause. That's why I never reported this issue. It turns out that it's not just my problem.
@Pat and @Li-Xiao Version 1.2 has a 'Reveal Workspace Folder' command in the Help menu.
Before resetting the app, use that command to get to this folder, zip it and send it to the developer.
@b77 Thank you! I know where the Workspace Folder is located, but the 'Reveal Workspace Folder' command in the Help menu is not working.
@Li-Xiao I confirm, nothing happens.
@Li-Xiao It is fine after resetting but the issue is indeed tied to my saved former workspace. It is there again after WS loading.
@Li-Xiao said in Impossible to trace with Pen tool:
'Reveal Workspace Folder' might still have problems on Windows.
As for the Pen toll problem, I could not replicate this issue with a simple test on an image.
Could you describe step by step (or a short recording) this issue. Thanks! -
@VectorStyler I've sent you the ".vswork" that are involved in this issue
@VectorStyler If the issue occurs again, I will record it.
@Li-Xiao I managed to replicate this issue. The fix will be in the next build.
