    Alternatives for 'drawing place' icons
    18 Posts 4 Posters 16.3k Views 4 Watching
    • AyoA Offline
      Ayo
      It's a good practice, learning and exploring Vectorstyler and at the same time getting rid of your problems and frustration.
      Now I stumbled over the 'drawing place button' and associated set of icons. Seemed more like a symbol for 'drawing geometric primitives' to me.
      Attached two proposals for alternative direction.
      Drawing Mode Icons-1
      simple and clean but possibly confusing with boolean functions.
      Drawing Mode Icons-2
      more illustrative.
      Also naming is different (app β€” manual)
      Draw on Top β€” Draw Normal
      Draw Inside β€” Drawing Target
        VectorStyler @Ayo
        @Ayo These look great, thanks! I will try to add them.
        AyoA H 2 Replies Last reply Reply Quote 0
        • AyoA Offline
          Ayo @VectorStyler
          It's just a sketch but do you want the .vstyler file?
            VectorStyler @Ayo
            @Ayo said in Alternatives for 'drawing place' icons:
            Yes πŸ™‚
            • AyoA Offline
              Ayo @VectorStyler
              Just curious;
              I just sent you the icon file. When you open that, is your entire canvas white? In other words, does the file take my settings with it? Otherwise it might look weird and I'll have to put everything neatly on an artboard in the future.
                VectorStyler @Ayo
                @Ayo Got the file, thanks!
                Yes, the canvas is white. This settings is stored in the document.
                • H Offline
                  Harry @VectorStyler
                  @Ayo
                  @VectorStyler said in Alternatives for 'drawing place' icons:
                  Those icons (especially version 2) look very good.
                  In my opinion, they should be all in the main toolbar, for example, next to snapping icons but with the separator. The highlighted icon (like for preview icons) would show the actual state of the drawing place.
                    VectorStyler @Harry
                    @Harry said in Alternatives for 'drawing place' icons:
                    It is possible to customize the toolbar and remove the current one icon that opens the menu and add the separate drawing place actions.
                    AyoA b77B 2 Replies Last reply Reply Quote 1
                    • AyoA Offline
                      Ayo @VectorStyler
                      Drawing Mode Icons and what became of it
                      Previously I made non-binding proposals for the drawing icons in this section because I thought it could be better.
                      Although it was still a sketch at the time not optimized, I now see that something has been done with it. It's just a shame that it has now become even worse. The icon set barely has any visual difference. And the highest contrast for the active part/subject is in the wrong place.
                      The editors of Vectorstyler do not have to adopt my ideas, but if they do something with them, make them better. The old set, ugly and incoherent as it was, was better at being distinguishable. You get used to that.
                      VectorStylerV H 2 Replies Last reply Reply Quote 1
                        b77 @VectorStyler
                        @VectorStyler What is the best way to distribute the custom icon set I made?
                        As .vswork files or as the new .vsicon?
                        .vswork is limited to the icons of the toolbox and the first
                        row of the context bar.
                        .vsicon allows me to change all the icons of the app but I'm not
                        sure how easy it is to install it.
                          VectorStyler @b77
                          @b77 said in Alternatives for 'drawing place' icons:
                          .vsicon is better. In this way the icons can be used "globally" in the app, not just inside a toolbox.
                            VectorStyler @Ayo
                            @Ayo Yes, there were some changes. The problem was at it did not work well in the dark theme.
                            I will try to make these icons look better.
                            • AyoA Offline
                              Ayo @VectorStyler
                              @VectorStyler How about something like this?
                                VectorStyler @Ayo
                                @Ayo I will try to add these.
                                • AyoA Offline
                                  Ayo @VectorStyler
                                  Sent you this file as outlines in case this is useful.
                                    VectorStyler @Ayo
                                    Got it, thank you πŸ™‚
                                    • H Offline
                                      Harry @Ayo
                                      @Ayo You are right. Here's how it looks on a 17" laptopβ€”you barely see the difference.
                                      But - from some distance, the pencil and the circle remind me of a magnifying glass:
                                      • AyoA Offline
                                        Ayo @Harry
                                        @Harry
                                        Thank you.
                                        You're right, that association also occurred to me. Now I have placed the pencil a little further away (as far as possible because space is limited in a square) and more away from pointing towards the center of the circle. Think that's better.
                                        Send an update of the file to Vectorstyler.
