    New document's artboard not visible/centered
    8 Posts 2 Posters 8.6k Views 2 Watching
    • H Offline
      Harry
      I have to zoom out a lot to see newly created document's artboard.
      Shouldn't it be centered? - video
        VectorStyler @Harry
        @Harry Is there a custom document template used here for the default document?
        VS saves the panning location when opening documents (or templates), but it does not when creating new documents.
        • H Offline
          Harry @VectorStyler
          @VectorStyler No, I don't have any custom document template.
            VectorStyler @Harry
            @Harry Not sure what could cause this. The defailt document settings are in the settings and workspace files.
            In the Help menu there is a Reveal Workspace folder command.
            This leads to the settings and workspace files. If you can send me those I will try to replicate this issue.
            • H Offline
              Harry @VectorStyler
              @VectorStyler Files sent
                VectorStyler @Harry
                @Harry This problem is caused by the resolution set in Display Options -> Resolution field. The value of 4096 is too high.
                • H Offline
                  Harry @VectorStyler
                  @VectorStyler Thank you - that worked. I don't have the slightest idea how this could happen 🙂
                    VectorStyler @Harry
                    @Harry No problem, it was still a bug, as it should have centered the view regardless of the resolution. The bug will be fixed in the next build.
