    Using node Tool nodes have only half the size of the size using the transform tool
    5 Posts 2 Posters 5.0k Views 2 Watching
    • chessboardC Offline
      chessboard
      Hello,
      I adjusted the "editor node scaling" to 200% (in preferences/path editor) and set all path indicators to "large" (in preferences/indicator styles) for use on a hires screen.
      Using the transform tool or the pen tool the nodes and indicators are now shown really big (too big 😉).
      But when I switch to the node tool those nodes and indicators now have just half of the size (except directly after closing the preferences window), which is now the size I would prefer. Switching back to one of the other both tools makes them large again, same with hovering over a path.
      It would be nice, if the scale of the nodes would be consistent for all tools.
        VectorStyler @chessboard
        @chessboard Some changes can be also made in the Settings -> Indicator Style section, by selecting the Large shapes for path nodes.
        Or (scrolling down) to the "Transform Selection Node" and setting "Small Circle"
          chessboard
          @VectorStyler Thanks for your quick answering. Unfortunately, that doesn't help. I have already set all the indicators to large. Setting the one for the transform tool back to small has not made any difference here.
          I'll send you a few screenshots for better clarification.
          Node size using pen tool:
          Node size when hovering with transform tool:
          Node size using node tool (seems to be half the size):
          Indicator size of transform tool:
          As said, I adjusted all indicators I could find to their large scale.
            @chessboard I will add a small increase for the default path node indicator size in the next build.
            chessboardC 1 Reply Last reply Reply Quote 1
              chessboard @VectorStyler
              @VectorStyler That sounds good! Thank you!
