    Path Sketch - adding and subtracting
    3 Posts 2 Posters 5.4k Views
      I really like the path sketch tool - thank you @b77 for bringing it up in conversation.
      I agree with you it might be worth making the last segment a different color or faded color to show it could still be edited. I was reading through the documentation and like the shift modifier options as well
      I could be wrong - but if i want to add to a selection - I would need to start from the inside of the existing shape and go out and come back in - and if I wanted to cut away from a shape, I would start outside the shape - go in and then come back out again. that seems to be the case most of the time - but every now and then I get a situation where it does not do that. I don't know how to cut down the video in record-it - but if you jump to the 55 sec mark - I duplicate a shape and then convert it to a predefined shape to see if it will also edit that - in doing so I ran into a situation where when I started inside and went out and came back in, it cut away instead of adding to it.
      I also notice there are times it does not recognize the existing shape as one I want to modify and instead makes a new shape over top. Is there a consistent way to make VS aware of what shape we are wanting to modify and when we want to make a brand new shape?
        @Boldline If you want to modify existing shapes, select the shapes with the pointer tool, and then switch to the Path Sketch tool. And you can start inside or outside.
          VectorStyler @VectorStyler
          @vectoradmin In build 1.0.045, the Path Sketch tool has an option to add or extract closed shapes.
