    Dragging many selected objects results in HUGE preview blocking everything
    10 Posts 3 Posters 8.6k Views 3 Watching
    • LoginErrorL Offline
      LoginError
      This doesn't always happen, but when it does I am unable to reposition those objects by dragging them as the preview blocks the entire layer panel.
      0_1710879882437_preview-bug-proof-of-concept.vstyler
        VectorStyler @LoginError
        @LoginError I opened a bug on this one, I think it can be improved.
        • L Offline
          Li Xiao @VectorStyler
          @VectorStyler In version 1.2.028, this issue has improved significantly, but it still occasionally occurs. During testing, there were sporadic crashes. I will provide a separate report once I can replicate the cause of the crashes.
            VectorStyler @Li Xiao
            @Li-Xiao said in Dragging many selected objects results in HUGE preview blocking everything:
            Is it crashing when you start dragging from the Layers panel?
            • L Offline
              @VectorStyler Dragging doesn't cause crashes, it only occurs when several factors are combined. After repeated testing dozens of times, I'm close to identifying the cause. The main factor seems to be related to cloned objects. Once I'm completely certain, I will record a video demonstration.
                If you have a file that crashes with clones / dragging, please send it to me.
                • L Offline
                  @VectorStyler Okay, I'll upload the files and video.
                  • L Offline
                    Li Xiao @Li Xiao
                    @VectorStyler It displays correctly when selecting a small quantity, but problems arise when selecting a large quantity.
                    https://youtu.be/OeMDopXHPXg
                    0_1718263456062_Preview.vstyler
                      @Li-Xiao I will try to replicate this.
                      • L Offline
                        @VectorStyler Thank you so much! Version 1.2.029 is working perfectly. I tested it by freely moving over 100,000 objects in the Layers panel, and everything is functioning correctly.
