    Offset between a cloned object and contour after blending
    6 Posts 2 Posters 5.7k Views 2 Watching
    • B Offline
      B-Vs-V
      Just a test: a simple shape is copied into a clone (Transform object) and a blend is applied between these two objects.
      By moving the cloned object with the Node tool:
        VectorStyler @B-Vs-V
        @Pat I opened a bug on this.
        • B Offline
          B-Vs-V @VectorStyler
          @VectorStyler There could also be a problem with the Smooth feature? I get nothing when selected.
            @Pat This should create a smooth transition between different colors, or (if the colors match) a single intermediary object.
            I tested this here and it seems to be working.
            If there is a file where the Smooth option is not working, please send it to me and I will try to replicate it.
              @Pat This can be replicated, but I have to postpone it a bit. This is a general problem with the blend spine path, that when changed the end object frames are not fully positioned. This is an issue with any kind of shape, not just clones.
              • B Offline
                @VectorStyler Thanks for the feedback. No hurry for me. I report anything that can be considered a bug ☺
