Contour Effect Issues
A few observations and questions. See pdf...
0_1720447086473_Contour Effect Issues.pdf -
Issue 1
Yes, this is intended. The original object is still selectable and can be copied (similar to Blend).
Issue 2
No this seems to be a bug, send me the file.
Issue 3
The original and the contour are separate objects. Group these two and then scale.
Same with the blend effect: group the 3 objects (starting, blend, ending). -
@Ayo I replicated the bug, will be fixed in the next build.
@VectorStyler said in Contour Effect Issues:
Thanks, but I'm left with the following questions... (see pdf)
0_1720515978526_Contour Effect scaling II.pdf -
@Ayo I will try to find a solution for this.
