build 157
VectorStyler beta 157 release notes
- Improved: added OpenType variable font support.
- Improved: color and variable fonts are shown with different icons.
- Improved: show number of font family members next to the name.
- Improved: added WEBP format for both import and export.
- Improved: added the Pixels unit.
- Improved: accessibility and Better Touch Tool support.
- Improved: 4 Point distortion should keep lines.
- Fixed: crash with certain open outline shifting mode.
- Fixed: text on path tool should work with local text baseline paths also.
- Fixed: touching the text baseline with the node tool to create text on path effect.
- Fixed: the Go Back button in the isolated editing indicator resulted in broken document state.
- Fixed: the name of a closed file may remain visible in the title bar.
- Fixed: assigning pattern fill from the fill popup preset list did not udate the object fill.
- Fixed: proportional scaling to also work when pressing Shift before the mouse press.
- Fixed: duplicating pattern styles did not refresh.
- Fixed: better indication of the collision point in the collider tool.
- Fixed: automatically group selected objects when activating a distortion effect tool.
- Fixed: organize gradient presets into folders.
- Fixed: Pen tool was broken when direct preview mode was disabled.
- Fixed: hue, color, saturation and intensity blend modes were broken.
- Fixed: crash when using blend modes.
- Fixed: pattern was not aligned globally when used in transparency.
