exporting slices
Every time I export slices(no matter how many or whatever profile) VectorStyler quits unexpectedly.
@wbjp I found some (possible) crash reports, but I could not determine the cause of the issue from there.
I tried to replicate this using some slice export tests, but could not crash it.There is a crash (I see the crash reports), I just cannot replicate it. If you have an example file with slices, and maybe a short recording of the crash, that might help.
The crash seems to occur in a UI element, so a recording is important to see how the slice export was used. -
Thanks. I put a video here and have attached the file.
@wbjp One thing to try: undock the Slice panel from the iconified panel toolbar and run the export from the undocked panel (so it does not close after export).
@VectorStyler That seems to have fixed it. Thanks!
@wbjp I will try to fix the crash for the next build.
