    update 1.0.039
    1 Posts 1 Posters 1.3k Views
      VectorStyler 1.0.039 release notes
      • Fixed: pencil eraser tool should not reduce the width profile to zero.
      • Fixed: refactor spot color handling UI in printer settings view.
      • Fixed: selecting a character style in the context panel did not work.
      • Fixed: cursor reverts to arrow after drawing the first shape.
      • Fixed: duplicating objects having a contour effect.
      • Fixed: scrolling with the mouse in numeric fields.
      • Fixed: ungroup multiple objects in the layers panel.
      • Fixed: cut self intersecting closed paths with pencil eraser tool.
      • Fixed: handling self intersections in winding shape normalization.
      • Fixed: shape builder to work better with self intersecting shapes.
      • Fixed: single click highlight of numeric fields.
      • Fixed: add a reset button to the printer settings view.
      • Fixed: adjust crop mark gap using the marker offset settings.
      • Fixed: show document bleed and slug values in printer settings view.
      • Fixed: repeating copy and rotate to use the actual pivot point.
      • Fixed: paste registers in undo as duplicate.
      • Fixed: exporting clipped groups into image formats used wrong bounding box.
      • Fixed: exporting some image effects may fail.
      • Fixed: combining objects with referenced shapes.
      • Fixed: ruler in paragraph view to use document units and allow scrolling.
      • Fixed: update path panel immediately when moving nodes.
      • Fixed: exporting flipped characters to SVG.
      • Fixed: SVG bitmap fonts did not render correctly.
      • Fixed: exporting bitmap fonts to PDF.
      • Fixed: rotate tool did not detect upper right corner.
      • Fixed: offset path on text shape did not show original if enabled.
      • Fixed: with of numeric fields in the properties panel.
      • Fixed: better layout in navigation panel.
      • Fixed: merge width profile when erasing from brushes.
      • Fixed: exporting gradients to SVG files.
      • Fixed: low zoom levels did not allow moving of small objects.
      • Fixed: pencil eraser tool may incorrectly remove objects.
