Some bugs/quirks
Hello,
I have found these bugs/quirks so far using the software:- Reflection tool doesn't use snap. I think it should do it because precision is needed working with vectors.
- Outline/fill color switch randomly stops working.
- No transformation arrows when working in crosshair mode.
- Color blends don’t work when exporting to SVG.
- Gradient fill expands limits to almost double the size when exporting in SVG.
I hope these can be solved
Thanks. -
@Fertuffo said in Some bugs/quirks:
I will open a bug on some of these:
I could not replicate this. At least the start/end points of the reflection axis snaps, but of course the shape does not.
Was this with keyboard shortcuts, or the color panel swap knob?
Yes, this is by design. I will try to find a solution.
This is a known open issue, will be fixed in the near future.
I will open a separate bug on this.
@VectorStyler said in Some bugs/quirks:
With swap knob
Thank you
I could not replicate this (gradient fill svg export).
Please send me a vstyler file that when exported to SVG results in expanded gradients, it might help replicating the issue.
There could be a number of other attributes (transforms) that might cause this.
Thanks!
