    Node tool, drag select - short key: How do I select and activate every nodes in same shape?
    11 Posts 2 Posters 8.7k Views 2 Watching
    • RaaskotR Offline
      Raaskot
      VS’ Node tool: Drag-LM selects nodes and make them active. Same thing with Adobe Ill but here you select and activate every nodes in same shape by pressing option.
      How does this works in VS?
        Subpath @Raaskot
        @Raaskot
        To select all nodes of a Shape
        use the Note Tool do a left click on
        the shape and press Ctrl+A on Windows
        instead of left click, hovering over a shape
        and press Ctrl+A works also
        RaaskotR 1 Reply Last reply Reply Quote 2
        • RaaskotR Offline
          Raaskot @Subpath
          @Subpath
          So cool, thanks!
            Subpath @Raaskot
            @Raaskot
            indeed 🙂
            but I have to correct myself a little
            select at least one node of that shape
            and then press Ctrl+A
            this will work better if you have many shapes
            • RaaskotR Offline
              Raaskot @Subpath
              @Subpath
              Thanks. Noticed the same when I tried it out, very useful. Like VS procedure better than in AI
                Subpath @Raaskot
                @Raaskot
                Had some trouble with my free video provider
                seems solved
                i like to add that using Ctrl + A for selecting all
                Nodes of a Shape has an additional Effect
                see this video here
                RaaskotR 1 Reply Last reply Reply Quote 1
                • RaaskotR Offline
                  Raaskot @Subpath
                  @Subpath
                  Very nice, thanks.
                  Cool tip with adding nodes. Off topic: How do you reduce nodes again?
                  The Simplify Path has no effect.
                    Subpath @Raaskot
                    @Raaskot
                    good question
                    of course undo
                    the only other ways i found was via History Panel
                    ( Menu > Panels > Edit > History )
                    or via a Lasso selection
                    • RaaskotR Offline
                      Raaskot @Subpath
                      @Subpath
                      Guess I'll report a bug ...
                        Subpath @Raaskot
                        @Raaskot
                        I was thinking about using the " - " (Minus) Key
                        for delete nodes was inserted via plus key ?
                        • RaaskotR Offline
                          Raaskot @Subpath
                          @Subpath
                          Would make sense with "-" --> node reduction, but it doesn't seems work.
                          And odd: It appears the reduce node function actually works yet on and off only. As if you must deselect and reselect the shape everytime.
                          Strange ...
