    Recolor woes
    26 Posts 4 Posters 30.6k Views 3 Watching
      VectorStyler @syllie
      @syllie The recolor view has been improved, it is still a dialog but it should behave better with the patterns.
      syllieS 1 Reply Last reply Reply Quote 1
      • syllieS Offline
        syllie @VectorStyler
        @VectorStyler The issues with Replace Color > Color from Palette seem resolved. Still testing through but the files that were misbehaving before now get recoloured as expected. And cancel is indeed understood as cancel. Very happy with that!
        Tiny inconvenience: if you click repeatedly on the 'Starting' counter, it occasionally skips numbers. https://go.screenpal.com/watch/cTnljynhrb5
        Windows 10 Pro | 22H2
          Subpath @syllie
          @syllie
          Numbers changing is also possible and works
          better on the left side of Number fields
          Set your mouse pointer upon the "Starting" Text
          press left mouse button and move the mouse
          up or down. That should also change the numbers
          and is more precise.
          syllieS 1 Reply Last reply Reply Quote 0
            That number skipping by using that little arrows
            is often the case, which make them more or less useless.
            I often use the drag Mouse methode on the left side
            because of that.
              VectorStyler @Subpath
              @Subpath I will find a solution for this.
              • syllieS Offline
                syllie @Subpath
                @Subpath Thanks for your input, and also the follow up with the other counters where you noticed skipping. For my case I just want increments +1/-1 and pressing the up or down arrow is faster and should be more precise than holding down a mouse button and dragging. Happy it is on the list to look into 🙂
                  Subpath @syllie
                  @syllie
                  Yes, there are different ways to change numbers.
                  I prefer to work with just the mouse and find using the
                  arrow keys is indeed helpful but not particularly comfortable
                  for me, as as a right-handed person you have to leave the
                  mouse to do so.
                  Using the mouse wheel works pretty precisely too. Unfortunately
                  not in all fields and not always in the same way. The steps are not
                  always the same (sometimes 1, sometimes 0.1 or more random)
                  It would be nice if changing a Value in a Number field
                  would work similar in all Number fields.
                  for me that includes also
                  up = 1
                  Shift + up = 10 Steps
                  Control + up = 0.1
                  down = -1
                  Shift + up = -10 Steps
                  Control + up = - 0.1
                    @Subpath said in Recolor woes:
                    Unfortunately not in all fields and not always in the same way.
                    I will try to replicate.
                      Subpath @VectorStyler
                      I did a Test in the Transform Panel (Object >Transform > Tranform)
                      OK, i realize that this may be a case by using the Mouse wheel.
                      Using the Arrow keys work fine.
                      will record a video later
                        Here the Video, this is the Transform Panel only
                        Object > Transform > Transform
                        but the ( Mouse wheel ? ) Problem exist in more
                        Number fields
                        Here the video
                          There is some Number skipping too, using the Mouse scroll wheel
                          and i dont understand why 0.? was using in % i am fine
                          with +1/-1 and using the Control Button if i need smaller steps
                            Not clear what is the issue here? is it the decimanls in % mode?
                              Sorry, my mistake the Skew Number field is in degrees °
                              but the numbers steps goes like this 2.5 °, 3.8 ° etc. instead
                              of 1, 2, 3 ... and so on. The same goes for Rotate.
                                this must be an error in the resources. I will fix it ASAP
                                  As already said thats only happen when using the Mouse scroll wheel
                                  in that Number fields, the arrow keys work expected counting 1, 2, 3° ect
