    Greyed Menu Items
    25 Posts 2 Posters 37.8k Views 2 Watching
      fdarnel
      @VectorStyler said in Greyed Menu Items:
      to customize the shortcuts
      Where to customize the shortcuts?
        VectorStyler @fdarnel
        @fdarnel Application Menu -> Keyboard Shortcuts
          fdarnel
          Well, I changed for Command-& in the setting, it works, but is now referenced as Command-7 in the View menu.
            @fdarnel said in Greyed Menu Items:
            I will try to sort this out. The cmd+1 in the French layout is the cmd+ampersand, which is cmd+7.
            I will try to sort these things out. BTW: there is also a UI translation planned before 1.3
              fdarnel
              OK, at least it works. If you need some help for translation.
                I will notify later on this for beta testing.
                  @fdarnel are there any other ways (besides the cmd+1) to get to this Greyed menus. I'm still trying to replicate it
                    fdarnel
                    It seems to be when using some shortcuts, not sure if it's only with cmd-1.
                      fdarnel
                      Hi, still the same behavior with the last version.
                        @fdarnel I still could not replicate this. Also tried on MacOS 15.3.1
