    Right click menu customizable
    7 Posts 3 Posters 8.8k Views
      @vectoradmin I know this was brought up before, but how feasible would it be to add the option of a totally customizable right click menu? Something that could be set to default and also returned to default as it is now, but then also offer the ability to create a custom set and name it and's swap to it in the preferences? It would be neat to add easy access to the high use functions.
        @Boldline Use the VectorStyler -> Contextual Menu command to customize contextual menus. In the Context drop down, select the context for which the menu is set.
          @vectoradmin ok - I can see more clearly how it already has numerous functions based on the context of what you are selecting and doing - very cool. I will try using it more as it is and make custom adjustments as I go along.
            encart
            @vectoradmin I have a suggestion. Could you move the Customize menu from View to Edit . For a long time, I didn't know this option existed because I thought all such options were available in the edit menu. It is a natural place for me for such settings. I bet it was the same for @Boldline . I only found out when someone mentioned it as you do here. I would only leave the Lock Panels on the View menu
              VectorStyler @encart
              @encart Will do so.
                @encart I got to retract on this one 🙂 I did move these commands on Windows to the Edit menu, but then I realized that at least for me, I have a better feel for Customization and Workspace commands to stay in the View menu for now.
                  encart @VectorStyler
                  @vectoradmin As for me, no problem, because I already know where to look for it ☺ . Perhaps I had a problem with that due to the fact that there was a lot of new stuff. What you say makes sense.
