    Graphic production?
    13 Posts 3 Posters 8.6k Views 3 Watching
    • M Online
      monsterfox
      Can VS achieve this graphic?
      • J Offline
        Jono @monsterfox
        @monsterfox This reminds me of the effect/trick you can achieve using Compound layers and contour tool in Affinity Designer. Afraid I don't know VectorStyler well enough if similar is possible.
        • M Online
          monsterfox @Jono
          @Jono Is this AD file the final effect? Can you share it? I'd like to know the detailed production details, thank you.
          • J Offline
            Jono @monsterfox
            @monsterfox Here's the method I used...
            • M Online
              monsterfox @Jono
              @Jono Thank you. Your method uses circles to create a blending effect. It's simple, but requires stitching and is a bit tedious.
              S J 2 Replies Last reply Reply Quote 0
                Subpath @monsterfox
                @monsterfox
                Achieving this metaball/Truchet tile effect seems like the easiest step to take.
                To get that halftone effect too is, at least, where my brain stop working.
                @Li-Xiao , did a Tutorial a while ago which works via the Repeater.
                Here the Link
                https://www.vectorstyler.com/forum/topic/3915/creating-a-truchet-tiles-using-repeater
                Just for inspiration. Here's a video from the Paragraphic YouTube
                channel showing how to create a similar pattern. I mentioned Paragraphic
                in another tread already.
                Here the Link to the video
                A search on Youtube "Metaball pattern", "Blob Pattern", "Truchet pattern"
                may also be helpful.
                • M Online
                  monsterfox @Subpath
                  @Subpath https://youtube.com/shorts/gHN57OiFCTs?si=RXZYx0E6eMVNJkNq
                  Maybe Li Xiao's method is indeed needed to complete this. Your information is very helpful. It's likely a combination of halftone and Truchet pattern. You can also take a look at that video.
                  • J Offline
                    Jono @monsterfox
                    @monsterfox said in Graphic production?:
                    Yes, doing things that way would be time consuming to say the least!
                    I'm going to look at the Repeater videos and resources (thanks Li-Xiao). I know I'm missing out so much of what VS can really do.
                      Subpath @Jono
                      @Jono
                      No need to worry 🙂
                      Even if you know much more about VectorStyler
                      you will still miss Features.
                      Because its such a deep rabbit hole 🙂
                      • M Online
                        monsterfox @Subpath
                        @Subpath This damned program—I’ve been using it for a year, and the more you use it, the more you realize there’s so much you don’t understand. I’ve never come across this in any other program. It’s a bottomless pit, haha.
                          Subpath @monsterfox
                          @monsterfox
                          Because I like to explore, find new things, new paths, and be surprised.
                          I am in heaven with VS. ☺
                          • M Online
                            monsterfox @Subpath
                            @Subpath Okay, if explorers find any interesting features, remember to share them. I'm following in your footsteps.
                              Subpath @monsterfox
