    Ability to move multiple selected objects at same time stops functioning
    6 Posts 3 Posters 2.8k Views 2 Watching
      I notice that if VS is left open for a long period of time - a day or two, that little wonky things start happening, such as the ability to move multiple selected objects at the same time stops functioning . If i select multiple objects one after another using the shift key to add to my selection and then click on them to be able to drag them collectively, it only moves one of them.
      Here is a video of this happening
      Closing out VS and restarting it fixes the issue
      VectorStylerV L 2 Replies Last reply Reply Quote 3
        @Boldline This will be hard to replicate, but I will try.
        • L Online
          Li Xiao @Boldline
          @Boldline I noticed the same issue a while back. I was planning to record when I had time, but looks like I don't need to now 🙂
            Boldline @Li Xiao
            @Li-Xiao Glad I could help!
            @VectorStyler is there something I can do when it occurs that I can send to you? Saving the file and sending it wouldn't help because the issue gets "fixed" on restart.
              @Boldline said in Ability to move multiple selected objects at same time stops functioning:
              What happens if you close the file and reopen it (without restarting VS)?
                I closed the file itself and reopened it. I did not close out Vectorstyler entirely
