Printer mark does not work properly (continued)
I will (gradually) move some of the fixed bug reports and implemented features to their respective subgroup.
They will still be accessible, and if the issue must be reopened, just post a new one with a link to the old one.Some additions will be made due to the above.
The basic functions seem to have been fixed.
As I mentioned in the previous post, it's better to fix the line widths of the marks.
Improvement: Each of the following should be set to 0.09mm.
-Crop:0.18mm <- too thick
-Bleed:0.18mm <- too thick
-Resistration:0.02mm <- Too thinIn the printing process after prepress, more necessary information is added to the Artboard by a special machine. These include more elaborate markers, process control checks, color balls, and various other data as needed.
However, I think the current function is sufficient for printing work that is done in the office. -
(1.0.042-043)
The line width of PrintMarks>Registration Mark is too thin.
(1.0.042-43) Bad result
Registration Mark is too narrow. The line widths of other marks are OK.
Current Registration Mark:0.011mm (0.03pt)Improvement point:
Improvement point: Use both pt and mm.
Change the line width of the Registration Mark to 0.088mm (0.25pt). -
@861475_VctSt For existing documents, it is necessary to reset the printer settings (Print -> Reset button at the bottom), to get the new Registration Mark design.
I did a clean install of V with completely removed (cache, settings, etc.).
I also reset the print settings.
The result was the same. -
@861475_VctSt I will keep the issue open.
v1.1.020
Mac OS X10.15.7
macbook air MId2012I cannot output PDFs such as printmarks, bleed, etc.
It also doesn't seem to be functioning properly.
Please check it out. -
@861475_VctSt When printing to PDF, select a larger Output size than the printed artboard.
I add this to the backlog, to clarify what is the issue. -
I guess I set a larger area than ARTWORK.
Oh, that's right.
I get it.thanks
8 861475_VctSt referenced this topic
