    Toggle option for Paste Keeps position
    11 Posts 5 Posters 3.7k Views 4 Watching
      I have "paste keeps position" active in my settings folder because when I cut or copy something, I want the default to be that it pastes back into the same exact location. That said, there are plenty of times I am copying an object from another part of the artboard and then panning over to another area and I am unable then to paste it in the new position. I resort to pasting and dragging the copy over to where I want it.
      In illustrator, there's a specific key command for pasting in place vs pasting in current view ; Command-F
      I'm not necessarily advocating for a dedicated key command for pasting in place, but maybe a modifier option to do the opposite of what the "paste in place" is marked for? Much like how we resolved the importing of images as a link vs embedded? or an option to paste on current screen position if the user has panned away from the original location completely?
      0_1758035757040_d5285237-09c4-46e9-84bc-90b8d25ded3c-CleanShot 2025-09-16 at 11.15.40.png
      M VectorStylerV 2 Replies Last reply Reply Quote 1
        monsterfox @Boldline
        @Boldline Now this function already exists, and it can be achieved by cutting.
          Boldline @monsterfox
          @monsterfox I'm not sure I understand. Would you be able to explain it further? If I cut a selection and then pan my screen and then paste, it pastes where it was copied from, not where I am currently on my screen. This is expected and wanted, I'm just looking for a modifier option to paste it where I currently am on screen
            @Boldline When you copy a graphic and then paste it, the graphic remains in its original position. However, if you cut a graphic, pan the screen, and then paste it, the graphic will be pasted in the middle of the current screen.
              @monsterfox Is there a setting or option for that?
              E 1 Reply Last reply Reply Quote 0
              • E Offline
                EricP @Boldline
                @Boldline personally, I would love an option where the object is pasted where I clicked (instead of screen center).
                Copy-Paste without clicking would paste in place.
                Copy-(pan)-click-Paste would paste where I clicked
                  @Boldline There is a Paste in Place (Edit -> Placing) action that can be assigned a shortcut.
                    @VectorStyler I turned off "paste in position" in the settings and VS still pastes in place even when I use command-v (not using the shortcut shift-command-v). Is there something else I need to change in settings so that command-v will paste wherever I have panned to?
                    VectorStylerV H 2 Replies Last reply Reply Quote 0
                      @Boldline said in Toggle option for Paste Keeps position:
                      I will test this.
                      • H Online
                        Harry @Boldline
                        @Boldline Did you try to hold Alt key while moving your object? It makes a copy to a new position.
                          Boldline @Harry
                          @Harry thanks - yes that is another way to accomplish it but I'm more referring to situations where you have an object on a different part of the canvas and want to paste a copy of it on a very different part of the canvas. It doesn't make sense in that situation to make a copy and then have to literally drag it over there to use. I like the option in settings to decide if you want it to default to pasting in place, but the ability to use a modifier to get the opposite would be helpful.
