    Add a distance / measurement tool for arbitrary points and objects
    15 Posts 4 Posters 570 Views 4 Watching
    • J Offline
      jpsimmons
      VectorStyler provides excellent numeric transforms and alignment tools, but it lacks a basic geometric primitive: direct distance measurement.
      There is currently no way to select two arbitrary points (or edges, anchors, or object references) and read the distance between them. This forces users into indirect workflows (duplicate-and-align, helper objects, transform subtraction), which are error-prone and unnecessary given VS’s internal precision.
      This limitation makes VectorStyler difficult to use for:
      • timelines and Gantt charts
      • diagrams and charts
      • technical illustrations
      • repeatable, metric layouts
      Historically, this exact issue existed in early Illustrator releases and was corrected decades ago when users needed numeric invariants rather than visual heuristics.
      Requested functionality (minimal):
      • A simple “Measure” tool (or mode) that:
      • lets the user click two points (anchors, edges, or arbitrary locations)
      • reports the distance (ΔX, ΔY, and Euclidean distance)
      • copies these values to the Transform->Move default values
      • is independent of snapping and alignment state
      This would not replace snapping or alignment — it would complement them by exposing the underlying geometry already present in VectorStyler.
      Given VS’s strong numeric infrastructure, this appears to be a UI exposure issue rather than a technical limitation.
        VectorStyler @jpsimmons
        @jpsimmons The Variable Values panel can be used to define number variables from various object measures. The variable value will be linked to the object and updated as the object changes.
        • J Offline
          jpsimmons @VectorStyler
          @VectorStyler said in Add a distance / measurement tool for arbitrary points and objects:
          How about a simple use case. I have two circles that are offset by some amount. I want to make a row of circles with that same offset. How do I do this?
          VectorStylerV E 2 Replies Last reply Reply Quote 1
            @jpsimmons A variable can only measure a property of a single object.
            • E Offline
              EricP @jpsimmons
              @jpsimmons said in Add a distance / measurement tool for arbitrary points and objects:
              I think you can use a repeater to achieve this, or a blend effect with 2 same circles. Other way is to use the transform dialog on your circle and choose number of copies and an offset
              • J Offline
                jpsimmons @EricP
                @EricP said in Add a distance / measurement tool for arbitrary points and objects:
                and an offset
                I have to manually put in the offset, if I know it. What I want is a way to automatically put the offset in from the GUI.
                  The only way to do this now is to use the width of an object to define a number variable and use that number variable as the offset.
                  Not sure if this covers it, but here is an example: offsetcase1.vstyler
                  • J Offline
                    @VectorStyler So, the feature request was to have a click two points and have that measurement auto load into the offset for translation. Nothing fancy-Illustrator has had it since Illustrator88.
                    It would just speed things up a lot to have this.
                    VectorStylerV M 3 Replies Last reply Reply Quote 0
                      The problem is that it is difficult to just link a value to two points clicked by the user. It has to be an attribute of an object, for example the length of a line.
                        monsterfox @jpsimmons
                        @jpsimmons Actually, it can be integrated with two paths. Then, by clicking any two nodes, the distance between the two points can be displayed in the Paths panel.
                          • J Offline
                            jpsimmons @monsterfox
                            @monsterfox That's an awful lot of work for something Illustrator had in 1988. I think all they did was note the location clicked the first time and the location clicked the second time and sent both coordinates to a callback that did the computing and loading.
                            Are you saying that VS works at too high a level of abstraction to get that kind of information?
                            J VectorStylerV 2 Replies Last reply Reply Quote 1
                            • J Offline
                              jpsimmons @jpsimmons
                              How about creating an abstract object called a "Measurement Line" that really doesn't get represented in the drawing, but has the locations of the end points. These can be used to compute the offset and to load the fields in the translate dialog box. Automate the process and free up the Measurement Line when done.
                                Can you show how this is done in illustrator?
                                • J Offline
                                  @VectorStyler Select the 'measure' tool from the toolbox. Click on the first control point. Click on the second. Bring up the translate dialog-it'll have the measurement between these two points loaded and ready to go.
                                  You can have another object selected and it'll translate that object when you hit 'ok'.
