    Vector Halftone setting cannot reach zero from scrubber. S
    3 Posts 2 Posters 9 Views 1 Watching
      In the vector halftone options panel, when I am adjusting the width option using the scrubber, it will not allow me to get to total zero. It stops at "0.01". I have to go in and edit it manually to be at total zero.
      My goal is to get rid of the stray lines outside the main area. I used a png image with a transparent background in hopes to avoid any of these extra lines. I was able to get rid of most but some still remain.
      I attached the VS file below
      vector halftone.vstyler
        @Boldline Yes, this is by design. I will try to find a solution for this
          @VectorStyler ok thanks! I attached the original image if that helps.
