Strange kind off hang using Drop Capitals
Hi! Im trying to use the Drop Caps but VS totally hangs when setting up them. In the video, after i changed the amount of capital letters at begining, VS totally hangs. You cant even close the program, the menu is not accesible anymore, and you cant do nothing. Only open taskmanager and kill it.
Here is the video -
@marce Same here, send me the file.
@VectorStyler Nothing special. A Text frame with some text copied. Anyway, here it is:
https://icedrive.net/s/5v2a1v8y92zakDX7i9wVAyX17QTz -
@marce I replicated the issue with the broken drop caps and the fix will be in the next build.
The app did not freeze, a modal view was open and must be closed before accessing the menu or the app window
@VectorStyler yes, it was an strange freeze, thanks the clarification
