    Unable to save files
    17 Posts 4 Posters 129 Views 4 Watching
      VectorStyler @richbyte
      @richbyte said in Unable to save files:
      @VectorStyler I tried using different names, locations. Re installed. Removed Application Support Folder etc. Same error.
      Can you make a recording of this, using the Save As command?
        @richbyte Do you have the Mac App Store version of VectorStyler?
        R 1 Reply Last reply Reply Quote 0
        • R Offline
          richbyte @VectorStyler
          @VectorStyler Yes Yes
            @richbyte I can send you a license for the downloadable VectorStyler version if that helps
            • R Offline
              @VectorStyler Thank you. I would like to try that if that works.
                @richbyte I sent one license to your email used in the forum
                • R Offline
                  @VectorStyler Thank you. I appreciate it. It works, 'saving' and 'save-as'.
                    stunthamster
                    Looks like I have the same issue - Mac App Store version of VectorStyler. Interestingly, I've noticed that it's not creating the
                    ~/Library/Application Support/NumericPath
                    directory on startup; not sure if that helps to track down the bug.
                      VectorStyler @stunthamster
                      @stunthamster I will test the saving with the app store version.
                      But, the for app store versions, user files are placed in some MacOS specific folders, not in this common Application Support folder.
                        @stunthamster I appears that app sandbox handling has been changed on MacOS, and this causes issues with VectorStyler.
                        I will try to find a solution ASAP.
                          stunthamster @VectorStyler
                          @VectorStyler said in Unable to save files:
                          Great stuff! Cheers for the quick turnaround on it.
                            @stunthamster The root cause of the file saving issue with the Mac App Store version was identified.
                            I will submit an update today, but Apple approval may take some time.
                              @stunthamster The file saving issue should be fixed in the newest app store version
