    Overlay effect needs improvement
    7 Posts 2 Posters 54 Views 2 Watching
    • L Online
      Li Xiao
      The Spacing for the Overlay effect needs improvement. Right now, the minimum spacing is limited to 1pt, but I need it to support 0 or negative values.
        VectorStyler @Li Xiao
        @Li-Xiao I will try to change this.
        But the Space is used only if closed shapes are overlayed.
        If the overlay contains open shapes this field is ignored.
        L 3 Replies Last reply Reply Quote 1
        • L Online
          Li Xiao @VectorStyler
          @VectorStyler said in Overlay effect needs improvement:
          I know it only works on closed shapes. Thanks!
          • L Online
            @VectorStyler Supporting negative values is absolutely perfect! Thank you so much
            • L Online
              @VectorStyler Recently, I noticed two areas where the Overlay effect could be improved:
              Repeat is currently capped at 100, which is far from enough. Could you increase this limit to support 1000 or more?
              Thickness is currently limited to a minimum of 0.3528 mm. Could you allow it to support a minimum of 0.1 mm?"
                @Li-Xiao Will make these changes
                • L Online
                  @VectorStyler These two updates are more than enough. Thank you so much!
