    VS lags when transforming masked objects
    4 Posts 3 Posters 14 Views 3 Watching
    • RaaskotR Offline
      Raaskot
      VS lags significantly when moving masked objects. Lesser with textboxes, but the overall performance is reduced in the document.
      The system is M4: Haven't noticed it before and wonder if it's a recent bug?
      lagging.vstyler
      See screen cast -->
        VectorStyler @Raaskot
        @Raaskot
        I tried to replicate this on a Mac Mini M4, this is what I get: https://cleanshot.com/share/GhGsW7ld
        Could be something in settings / workspace causing this.
        What happens if you restart VS?
        RaaskotR L 2 Replies Last reply Reply Quote 1
        • RaaskotR Offline
          Raaskot @VectorStyler
          Edit:
          Also the textboxes appear laggy again after screen record
          Tried:
          Closing all other apps
          Settings/Restore Default
          Restarting
          The textbox' performance is improved (better yet not visible due to screen recording), but the masked objects is heavy in real life.
          https://somup.com/cO1T6pVnQCP
          • L Online
            Li Xiao @VectorStyler
            @VectorStyler I tested this on a base model Mac mini M4. Moving the text in the top left corner is perfectly smooth at first. However, moving the masked object in the bottom right causes lag. After that, moving the text in the top-left becomes laggy as well.
            https://youtube.com/shorts/Zv0shwdhanc?feature=share
