    Strange results and behavior while editing inside a clipping mask
    14 Posts 3 Posters 38 Views 2 Watching
      I clipped vector flames inside of a blue text mask. When i go to edit the inset flames, I get strange results as shown in this video.
      Below is a photo of one example of the odd behavior i the video. Another example happens too quickly to capture in a still image, but its like the clipped shape is fully visible for a moment.
      Here is the file in the video:
      clipping mask issue.vstyler
      VectorStylerV 3 Replies Last reply Reply Quote 1
        @Boldline I will try to replicate and fix this.
          @Boldline Is this with GPU view?
            @VectorStyler no, it was not activated this time
              @Boldline Could not replicate this here
              BoldlineB L 2 Replies Last reply Reply Quote 0
                @VectorStyler just sent you by email the workspace settings files - in case that helps
                • L Online
                  Li Xiao @VectorStyler
                  @VectorStyler I have tested this on both macOS and Windows, and the issue illustrated in the image occurs on both platforms.
                    @Boldline Can be replicated with the workspace you sent.
                    BoldlineB 2 Replies Last reply Reply Quote 2
                      @VectorStyler Awesome! thanks for checking that. I'm guessing @li-xiao has a similar workspace setting that allows it to occur on his computer as well.
                        @VectorStyler This issue seems to be resolved in build 23 that you released today! I created a new example with a couple vector objects clipped inside a shape and then edited them and it worked perfectly. I went back to the old example from this thread and the issue remains, but instead of flashing, the shape stays visible outside the clipping shape when actively edited. What I did notice was that in this example, the orange was always the issue even when it was the yellow shape I was editing.
                        Here is a video where I show both examples - the new one that works and the old one that still has an issue in build 23
                        Here is the file from a couple weeks ago uploaded again for comparison with the new build 23 fixes.
                        clipping-mask-issue.vstyler
                          @Boldline said in Strange results and behavior while editing inside a clipping mask:
                            @VectorStyler I had a little more time to investigate. The old file works perfectly in default settings on Tahoe. It still has the issue I made a screen video of today when I am using my custom settings. My custom settings in Tahoe were no issue with the new sample I used in the screen video. I can send you those settings
                              @Boldline send me the settings
                                @VectorStyler just sent! thanks
