    Raster Image + Outer Glow = Image Not Rendered
    5 Posts 2 Posters 18 Views 2 Watching
    • nocturnalYLN Offline
      nocturnalYL
      RasterTest2.zip
      And then I added an outer glow effect and exported it, and it looks like this → RasterImageTest2.png
      It doesn’t seem to affect other effects. Inner glow also works fine.
        VectorStyler @nocturnalYL
        @nocturnalYL
        I will open a bug on this.
        But, can you save the file after exporting, then the exact export options are also stored in the file and I can use the same options
        nocturnalYLN 1 Reply Last reply Reply Quote 1
          nocturnalYL @VectorStyler
          @VectorStyler The attached file (the RasterTest2.zip link in my first post) should already contain the export options I used. I saved immediately after exporting.
            @nocturnalYL
            One think to try as a workaround: do not add effects in the Appearance panel (as adjustment effects), instead use the Image Effects panel to add the effect on the image
            I could not replicate yet the export issue (using the export settings).
            But I will try to find out more on this
            nocturnalYLN 1 Reply Last reply Reply Quote 0
              @VectorStyler I think it might be because I use software rendering.
              test.zip ← Test image
              data.zip ← Config in %LOCALAPPDATA%\NumericPath\VectorStyler1.3\vector\data
              Changing it to CUDA causes the export to render incorrectly sometimes (like what this user experienced: https://www.vectorstyler.com/forum/topic/4393). OpenCL seems to work fine for both in-app rendering and exports, so I'll use that for now.
