    Change Stroke Display Field from 0.0 pt to Hairline
    8 Posts 3 Posters 10.9k Views 1 Watching
    • V Offline
      Vector-Rock
      @vectoradmin,
      User Interface Improvement:
      I would like to see VectorStyler use the word Hairline in the Stroke Display Field instead of the numerals 0.0.
      In addition to being the industry standard term and used by other vector programs, it would make it consistent with how VectorStyler already shows it in the Stroke drop-down menu.
      Example of CorelDRAW:
      0_1626246677361_CorelDRAW_Property-Bar_Hairline-Stroke-Setting_Annotated_VectorStyler-Forum_Post_Resized-11.png
      ** Edited and Moved to New Features and Ideas*
      VectorStylerV b77B 3 Replies Last reply Reply Quote 1
        VectorStyler @Vector-Rock
        @Vector-Rock Added to the backlog.
          @Vector-Rock This should be fixed in 1.0.044
          V 1 Reply Last reply Reply Quote 1
          • V Offline
            Vector-Rock @VectorStyler
            @vectoradmin said in Change Stroke Display Field from 0.0 pt to Hairline:
            @vectoradmin,
            Thank you for changing this.
            A nice UI improvement that both provides VectorStyler a more accurate depiction and a professional look!
              b77 @Vector-Rock
              @Vector-Rock I just found yesterday that now if I enter '0' (zero) in the width field OR drag the width slider all the way to the left, the app switches to 'Hairline' instead of 'None'. What is the advantage of this behavior?
              V 1 Reply Last reply Reply Quote 0
              • V Offline
                Vector-Rock @b77
                @b77 said in Change Stroke Display Field from 0.0 pt to Hairline:
                There is no advantage to this behavior. It is a bug. None/0 (zero) should be a distinct and separate Option Setting from Hairline.
                @vectoradmin must not have noticed it after an update. I'm guessing it will be fixed in the next update.
                  @Vector-Rock This is a bug and will be fixed.
                    b77 @Vector-Rock
                    @Vector-Rock @vectoradmin 👍
