    Issues with effects applied
    10 Posts 4 Posters 9.9k Views 1 Watching
    • G Offline
      gentlecl
      Using the open cl computation method most effects have a grey box surrounding them after the effect is applied
      Gaussian blur
      I think the grey box is th actual alpha channel , the dropdown shadow also shows the same issues
        VectorStyler @gentlecl
        @gentlecl What is the GPU type?
        • G Offline
          gentlecl @VectorStyler
          An old amd radeon , which I think is not compatible , but I am using software renderer
          Here's the shadow dropdown effect applied
          The copy doesn't render completly , and zoomed it looks like a bitmap
            @gentlecl At higher zoom levels, some image effects will render at low resolution. This can be changed using the View -> Display -> Display Options -> Images -> Filter Precision field (50% by default, 100% means full resolution, but blur can be very slow).
            Also: do not worry about the preview at high zoom levels, when exporting to image file formats, the filter is rendered at 100% precision.
            • G Offline
              gentlecl
              I am more worried about the partially copied objects , why certain elements are cut off abruptly ., the grey bouding area etc..
              As it is now , for me the stylize effects are not usable , maybe it's becasue of the gpu hardware incompatibility ?
              either way , I think you have a winner on your hands !
                @gentlecl I will look into the cut off issues. Is there an example file you could send by email to csraba at vectorstyler.com. It would help replicating the issue. Thanks!
                • G Offline
                  gentlecl
                  How can we upload files ?
                    @gentlecl VS files don't get uploaded here - just images and links to videos. Email any working files to @vectoradmin
                    csaba at vectorstyler.com (I am pretty sure he misspelled it above)
                      b77 @gentlecl
                      @gentlecl Send the file to csraba
                        @gentlecl Fixed in build 1.0.046
